Posted by Janicholson on April 01, 2014 at 20:08:59 from (74.60.94.18):
In Reply to: Farmall m hydraulics posted by Bad luck on April 01, 2014 at 17:54:54:
If the hydraulic return line is plumbed into the fill pipe under the tank, it might only need the return plumbed into the drain hole with a "T" fitting. The rush of returning oil can splash out and run out the fill cap. If the cylinder/s are 2 way, the top of the cylinder/s can be hosed to th reservoir allowing a near neutral balance of oil in the reservoir. This would allow the cap to be non vented. If the cylinder/s are one way only, the top of the cylinder/s should be vented, and the cap should also have a vent. The use of the return into the bottom is a solid solution if the valving is not a "christmas tree" IH valve (which attaches to the inlet pipe as a mount) Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
