Re: 826 park lock
Posted by DeltaRed on April 01, 2014 at 21:37:37 from (65.100.144.27):
In Reply to: 826 park lock posted by Pete on April 01, 2014 at 14:37:35:
Yes, you can 'pull' the reverse shifter out if you are not careful.Just watch as you lift the cover.As was said,if the key gets dropped,then ya gotta pull the hitch pump and retrieve it.BTW,remove the (reverse) cover plate(by the clutch pedal) .Gives a better veiw.
