Posted by Owen Aaland on April 01, 2014 at 22:22:29 from (216.47.34.188):
In Reply to: Farmall m trouble posted by Smitholm on April 01, 2014 at 19:50:49:
The belly pump doesn't put out enough pressure to kill the engine like that. If the detent spring breaks and get sucked up in the pump gears the normal result is either a sheared pump gear key or the threads striped out on one of the drive couplers.
Also the compression readings are what you see when the camshaft is not turning. An M with an aftermarket live hydraulic pump was noted for breaking the camshaft gear unless it has been replaced with the later, heavier gear. A system with a non working relief valve can easily break the camshaft gear.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
