Posted by El Toro on April 04, 2014 at 10:00:59 from (96.244.7.206):
In Reply to: 460 Gas Wont Start posted by JC3 on April 04, 2014 at 09:33:28:
Hold your hand over the throat of the carburetor and see if there's good suction. Also do a compression test and post the readings. Poor suction indicates low intake manifold vacuum. Make sure your intake manifold isn't the problem. Tighten the bolts or nuts. Also squirt some engine oil in all the cylinders then replace the plugs and see if the engine will fire. I would recheck the valve clearance. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
