Re: 460 Gas Wont Start
Posted by ken house on April 04, 2014 at 10:30:48 from (173.242.240.240):
In Reply to: 460 Gas Wont Start posted by JC3 on April 04, 2014 at 09:33:28:
i am sure that you have given it a sniff of ether. if it does not hit on ether, you may have some bad gas. try draining gas out and putting in some fresh.
i cannot say this for sure, but, i had an engine that would not start, would not hit with ether, i blamed it on bad gas.
