Re: 460 gas oil pressure
Posted by Janicholson on April 04, 2014 at 19:54:06 from (74.60.94.18):
In Reply to: 460 gas oil pressure posted by Old weldor on April 04, 2014 at 17:50:21:
Oil pressure lines can be small because the fluid does not compress. Normally on those I am framiliar with, they are one eighth inch dia. It just needs to move the gauge mechanism by reshaping a Bourdon Tube. Cubic Millimeters of flow. The temp gauge is operated by a capillary tube with a fluid (like Ether) contained in it and the sensing bulb on the engine end. it is very thin as well. Jim
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
