Posted by Janicholson on April 05, 2014 at 20:05:02 from (74.60.94.18):
In Reply to: oil pump on 300 posted by bill gaw on April 05, 2014 at 18:33:36:
It can be well lubed up with petroleum jelly, no need to pack it full, just nice and "greasy". I also recommend pumping oil into the engine through the oil pressure sending fitting on the block. Use a pump oil can and a bit of tubing to make a temporary seal. This will fill the oil passages and provide oil pressure rapidly. It may take a few loadings of the oil can, but you will know when it is primed as the oil can will be harder o pump. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
