Re: H gear oil leak
Posted by Janicholson on April 06, 2014 at 12:46:13 from (74.60.94.18):
In Reply to: H gear oil leak posted by thdrduck on April 05, 2014 at 06:01:54:
There are 2 possible leak points if smelly gear oil is leaking (and not Hydraulic oil). The trans input shaft seal (mutch harder and does require pump removal, and countershaft driven pump coupler seal (Much lower in the trans) The lower one is easy, the upper one requires removing the clutch shaft and coupler to the trans input shaft. No split, but awkward. Many posts in the archives. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
