Re: finally got me a big tractor
Posted by 1970-1655 on April 07, 2014 at 13:53:12 from (166.147.104.167):
In Reply to: finally got me a big tractor posted by rebelbull on April 07, 2014 at 09:39:20:
What do you have the throttle set at when trying to start it? If it is all the way up, that is the fuel stop to shut off the engine. Open it up a little and try again.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
