Posted by CNKS on April 07, 2014 at 17:56:12 from (12.170.61.29):
In Reply to: Lift-All fluid posted by AlanA on April 07, 2014 at 12:11:23:
If you are the only one using the implements 30 weight is ok, and probably better than lighter oils. Non detergent is on the safe side, but my dad was using SAE 30 detergent in the 50's in both the engine and the lift all on his H. The hydraulics were used a LOT, detergent worked fine.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
