HI I have one apart now. There is no pin or stud to realign. The casting is heavy maybe 80#, or more. Under the seat are threaded holes. Get some bolts to fit and you have a spot to hitch an engine hoist, block & tackle, whatever. Before lifting, try to move the casting sideways. You may be able to save the gasket to re-use. Hit a piece of wood on the casting with a 12# hammer, not hard, just a good thump or 2 on each corner. Budget a new gasket as the "in a tube" stuff will most likely leak somewhere. Get some threaded rod with same thread as main mounting bolts. Use 4- 8 inch sections (on the corners)just finger tight to hold the gasket in place. Then lower the tank down over the threaded rods. Then put in the other 8 bolts, then remove rods and put in corner bolts, tighten up. Oh yeah, number the bolts as you remove them as there are different lengths. d
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
