Re: 460 with missing serial number plate
Posted by RPM1941 on April 09, 2014 at 07:12:53 from (173.18.253.242):
In Reply to: 460 with missing serial number plate posted by Hugh McKinney on April 08, 2014 at 19:14:20:
When I first started working at a SW Iowa IH dealer in June of 1960 I hauled the updates in a pickup from Omaha IH warehouse. They were in a large & heavy wood crate. The 460 got new bull gears & brake pinion shafts, some bearings for various places in rear axles, transmission & differential. When completed the mechanic was to make a triangle stamp on the serial number plate. I can tell you if the rear end is apart it is easy to identify the bull gears by the 25% pressure angle of the gear tooth. Otherwise I can think of no easy way to id the upgrade from outside.
