OK let's take this one step at a time. In your post title you say 'Farmall H stuck in gear'. Not sure why you are saying that. You don't refer to it in your post. Could it be your engine is stuck? You ask if the brake shaft is connected to the drive. What do you mean? All I can say here is that the drum that the brake band is around is directly geared to the wheel on the same side as the brake. You should not be able to move the drum much unless the wheel is allowed to turn. As far as the gas situation goes, there should not be any gas leaking from anywhere when you turn the shutoff to the on position. If it is flowing out of the carb, my guess is the float is not moving and the needle valve can't shut off the flow of gas to the carb bowl. A carb cleaning would be in order. Not sure if that helps at all. Your post is not very clear to me as to what your problems are.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
