444 stalling when idling
Posted by Don in MN. on April 09, 2014 at 13:17:52 from (72.168.96.184):
Last fall I was using my 444 to do some land scaping. Temp out side was about same as today[6o]Had it idling and it quit runnig. Let set for 10 minute or so and started right up. I used it all winter to plow snow and haul wood, and never had a problem. Today I was using it to knock down snow piles to make winter go away. stopped to pick up some branches, had it idling and it stopped. Happened twice. Is it warm enough out to be vapor locking? Temp gauge was 140 Let it set for a few minutes, and started.Any idea's?
