Brake adjustment on an 'H' is not quite like that. Here's my procedure I finally figured out.
To Adjust / Tighten Up Brakes; [To Move Brake Pedals Closer to Transmission Cover; ] Un-do bottom locknut on bottom of brake drum housing. Then re-adjust bottom square-head bolt up firmly, then down ~ ½ / ~ ¾ turn. Tighten the bottom locknut BUT NOT TOO TIGHT, you may rip it out. Remove cotter pins. Un-do the rear portion of the springs. Remove the clevis pins. Thread IN the clevis to tighten up the brakes. [1 full turn moves brake pedal ~ 1/8” closer to transmission cover.] Reassemble. Do each side evenly, so tractor brakes evenly left/fright.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
