Posted by John G. Hasler on April 09, 2014 at 15:12:26 from (174.124.66.163):
In Reply to: Re: TA Use-do don't? posted by pete 23 on April 09, 2014 at 10:35:28:
> The TA is a wear item weather you use it or not. > Every time you push the clutch on a mechanical > planetary TA you are releasing the TA direct > drive clutch. This wears the throw out bearing, > clutch fingers etc.
I think that the number one cause of wear on the TA clutch is failure to keep it properly adjusted. Don"t ignore the TA when you adjust the engine clutch linkage just because you never use it. If that throwout bearing goes it can ruin your whole day. The TA inspection port cover on my 544 has a dent in it. From the inside.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
