Re: C-20 Plow point bolt
Posted by AG in IN on April 09, 2014 at 21:37:33 from (67.236.77.175):
In Reply to: C-20 Plow point bolt posted by Rex Simpkins on April 09, 2014 at 15:39:12:
There's 3 different possibilities you could be asking about.
1. The top retaining bolt is fine-threaded with a rectangular head. Bolt has 4 radial lines and is the equivalent of a Grade 6 bolt.
The bolts in the center of the point have two possibilities.
2. Most common is a hex-headed bolt. 1/2"NC and either 3/4" or 7/8" long (don't remember). Hex bolt was used for all later steel points. Originally had 4 radial lines, and was swithched to a Grade 8 bolt when IH discontinued their Grade-6 equivalent hardware.
3. Goofy bent head bolt that sorta looks like a plow bolt that goes through the point. It was used on earlier steel points and all chilled points.
You're probably asking about #3. I'll try and get some pics tomorrow.
AG
