Re: A-freeze in oil
Posted by dej(Jed) on April 10, 2014 at 04:54:11 from (141.189.113.1):
In Reply to: A-freeze in oil posted by classicxl on April 09, 2014 at 19:17:59:
The tractor must have not been run in a while because the antifreeze came out seperated from the oil. Usually it gets emulsified into the oil and the oil will be gray colored. I have used the aluminum seal too and I agree, it works well. You could pull the pan and check, but unless the leak is major, you probably won't see anything. I got a sealer one time that you added to the radiator, heated the tractor up, drained the whole system and left the system open for 24 hrs to allow the sealer to set up. That worked well. Also you could examine your plugs to see if one is a bit fouled. This might give you an idea of where the leak is located. All in all I would probably just go with the sealer and simply keep an eye on it. Oil can carry a lot of water before problems occur. Good luck.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
