With a Coil terminal connected to a true 12v coil with no ballast resistor required written on it, it will be fine. if the primary resistance of the coil is about 2 to 2.5 ohms on an accurate meter, the coil needs a ballast resistor. The ACC wire goes to radios, or accessories (or the lights if you want the key to control their on off status. The AMM terminal hooks to the load side of the Amp gauge. (opposite the one connected to the starter switch) Your key is no different than the original push pull switch except for the ACC terminal which you probably don't need. There will be no starter relay as your switch is not a start equipped switch, and a rod is used to start the engine. The diagram supplied should work if it is a generator. or the Alternator supplement if Delco. 10SI Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
