Re: 1953 Super A piston rings
Posted by CharlieNJ on April 12, 2014 at 04:39:51 from (76.117.68.151):
In Reply to: 1953 Super A piston rings posted by jondenuke on April 11, 2014 at 18:59:51:
The last ring set I bought came from this website, delivery was very fast, rings were good, price was right. Go to the parts section, you will see there are 3" and 3 1/8" cylinder bores. Also, there are different size compression and oil rings, for instance, 1/4" or 3/32" compression rings, and 1/4" or 3/16" oil rings. The year and serial number don"t mean that much after 60 years, just measure things up. For torque, a service manual will list those specs, the manual is available on this site, too. From memory, rod bolts might be 35 ft. lbs. and the head bolts might be 65 ft. lbs. but most people on here will tell you to go to 80 ft. lbs. That said, I once pulled the threads out of an A block head bolt, heli-coil fixed it. Go to this page and check it out...
