Hi, the shift mechanism is all under the where the shift lever is located. The mechanism is probably worn. Make sure trash has not fallen done into the shift mechanism or the sheet metal that guides the shift lever is not bent.
Are the gears grinding when you shift into forward? Could be clutch not releasing properly.
DO NOT force the shift lever or you will shear off the lever that goes into the transmission.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
