Re: 1953 Super A piston rings
Posted by El Toro on April 12, 2014 at 06:09:19 from (96.244.7.206):
In Reply to: 1953 Super A piston rings posted by jondenuke on April 11, 2014 at 18:59:51:
Some of those late Super A's had the same block that the Super C used. You should measure those sleeves for wear or have someone to measure them for you. If it was my tractor I would install a new sleeve kit. Also have the crankshaft measured for wear at your local auto machine shop and buy the new bearings from them. Then you will have an engine that will last a long time.
The Farmall A's, B's and C's and some of the Super A's had sleeves that measured 6.875" in length and 3.312" in diameter at the seal.
The Super C's and some of the late Super A's had sleeves that measured 7.060" in length and 3.4375" at the seal. Those engine blocks had block number 354898R1 and you could install an overbore kit that raised the cid to 133. Hal
