W4 Choke Rod
Posted by Tim in New York on April 12, 2014 at 16:13:47 from (199.58.145.25):
My W-4 was cobbled up with a choke cable fastened up near the steering wheel. It sticks when I start it, and I have to jump off and manually flip the choke off before the engine dies. And sometimes when it sticks, gas runs out of the carb and makes a mess.
I seem to recall the original setup was a small rod that was attached down near the starter button. Does anyone know of a source for these? I found a choke rod for the H in one of my catalogs, but I don"t know if that will fit. I also don"t know if I am missing some pieces in addition to the rod.
Thanks,
Tim
