Re: Farmall A oil in radiator
Posted by Janicholson on April 12, 2014 at 17:27:15 from (74.60.94.18):
In Reply to: Farmall A oil in radiator posted by red bearing on April 12, 2014 at 17:22:15:
Usually an indication of a head gasket leaking at the passage where the rocker arm is fed oil up from a cam journal. A combustion gas detector kit used in the radiator will tell you if it is getting compression into the coolant. I fnone, I would flush out the cooling system with a flushing product, and refill with new. then watch for oil. Jim
