Posted by Red Mercury on April 13, 2014 at 13:16:06 from (204.112.30.247):
In Reply to: 6V battery calbes posted by HenryV11 on April 13, 2014 at 07:10:02:
HenryV11 said: (quoted from post at 15:10:02 04/13/14) I replaced the battery cables on my 6V W-9 with 2/0
welding cable. The starter turns the motor over faster than before. How high should the liquid be in the battery cells? Mine is just covering the plates.
I have had this tractor for over 40 years. I wished I had changed those cables back in the day when it was my main tractor.
Yes, that is the best & easiest thing to do for a 6V tractor. I have seen several hard starting 6V tractors with small battery cables. I am just going to add a simple explanation here in case others don't quite understand the science behind using larger cables. The larger cables reduce the voltage drop that occurs across the cables during starting, meaning there is more voltage available at the starter terminal. The same voltage drop will occur on 12V tractors too, but since the battery voltage is higher the voltage drop across the cables isn't as noticeable.
This post was edited by Red Mercury at 13:16:47 04/13/14.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
