Re: Getting points open to measure gap
Posted by Nebraska Kirk on April 13, 2014 at 13:38:09 from (207.91.4.159):
In Reply to: Getting points open to measure gap posted by clint s on April 13, 2014 at 13:21:38:
I usually use the hand crank to turn the engine until the points are open, but then all my tractors have hand cranks. On those few that did not have hand cranks, I just turned the engine over by hand by holding the fan belt tight with one hand and turning the fan with the other. This usually works to turn the engine over enough to open the points.
