Re: International 240 Utility timing help!!!!
Posted by Mark Robke on April 13, 2014 at 15:48:45 from (98.19.76.216):
In Reply to: International 240 Utility timing help!!!! posted by Gorder on April 13, 2014 at 11:46:41:
#1 is the front. If you are at #1 tdc on the crank pointer, and the rotor points at 7 o'clock,then #1 wire goes there. Then 3,2,4 in direction of rotation of the rotor. If you don't know the rotation of the rotor, just turn the engine fan, or easier yet, just crank engine with key and observe. Mark
