Re: Farmall M throttle and steering
Posted by charlie M on April 13, 2014 at 16:17:44 from (173.85.163.42):
In Reply to: Farmall M throttle and steering posted by bja105 on April 13, 2014 at 16:00:20:
Never seen a baler ran like that before. Is the tractor missing a PTO or the baler. Concerning the throttle and steering, the only connection is they are attached to the same steering post. If your throttle is the newer style with a friction disk instead of teeth it doesn't take much for the throttle to move on its own if the disk is worn or if the bolt to tighten it down needs tightening. New disks are available and you can try tightening the bolt that holds the 2 halves together. If you have an older style throttle with teeth them probably some of the teeth are worn down so it doesn't hold.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
