Re: Farmall Cub Plow set up
Posted by Ivan in Mich on April 13, 2014 at 21:09:52 from (174.125.91.197):
In Reply to: Farmall Cub Plow set up posted by baydog1 on April 13, 2014 at 20:34:01:
Did you get the depth control lever with it. It bolts on the side by the fender and a rod goes down to the draw bar. Yes you have to turn the draw bar around and bolt it to it. I had the same proble until I put the adjusting arm on the trac
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
