Re: Getting points open to measure gap
Posted by SadFarmall on April 14, 2014 at 00:38:36 from (112.213.174.150):
In Reply to: Getting points open to measure gap posted by clint s on April 13, 2014 at 13:21:38:
On Farmall H and M tractors I use the hand crank to and get an assistant to watch the distributor cam. Works for magneto and coil ingition systems. Set the gap when the bakelite block is at the highest point of the cam on any cylinder. My experience with petrol and kerosene motors of all sorts is that breaker point gaps tend to close down with wear and spark plug gaps tend to open slightly. Setting the timing on a magneto engine is easy. Setting the timing on a coil ignition Farmall is something I have never done - all my tractors are magneto.
SadFarmall
