They are correct. You remove the drawbar, turn it around, and mount it to to the front set of holes in the final drives.
There are pins or bolts that you also need to remove to allow the drawbar to pivot up and down.
There is also a depth control lever that mounts to the right final drive and connects to the flipped-around drawbar. It has a handle with a latch that you can operate from the driver's seat.
The plow should be mostly underneath the tractor, with the chain almost vertical. If it hangs way out the back, you've done something incorrectly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
