Posted by Jeffcat on April 14, 2014 at 10:15:07 from (173.72.26.60):
In Reply to: fuel problem? posted by farmall4856 on April 13, 2014 at 16:38:06:
I am betting a lot of people are going to find problems like this come warm weather. We had one he-- of a cold and damp winter and any half a--s problem is gonna show up to bust our butts. Check for corrosion on your little contacts in side the dist. cap. The CHEEEEEP caps have aluminum where the good ones are copper. Look at the rotor and that little carbon. LOADS of headaches!!! Spray the cap inside with a little brake cleaner to remove any oil or grease. This will cause the spark to run around inside the cap. Points are another thing and also a distributer in need of a rebuild is the last stop. If this is a 6 volt tractor the problem factor just went up. Everything needs to be clean and solid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
