Re: 300 runs wont run
Posted by DeltaRed on April 14, 2014 at 11:36:56 from (65.100.144.27):
In Reply to: 300 runs wont run posted by greg potts on April 14, 2014 at 11:16:48:
Fuel flow.If you have good flow from the bowl,good flow to the carb,Pull the screen from the inlet at carb.If thats clean,you probably have some crap in the needle.Disassemble carb,unscrew seat. the 'crap' will be there.Pull the drain pulg from the bottom ofd carb. Let run for 3-5 mins. fuel should run out the entire time.If not,there is a blockage.
