Re: Farmall 300 clutch problem
Posted by mkirsch on April 14, 2014 at 11:41:08 from (65.199.189.6):
In Reply to: Farmall 300 clutch problem posted by Danny D on April 12, 2014 at 12:16:10:
Unless the wear marks were extremely bad, I don't see how that could be your problem. I would have expected the problem to have happened all at once, and soon after the rebuild.
I suspect either you got a bad clutch disk, or you bent the clutch disk putting the tractor together, and now it's coming apart. If you don't use the clutch alignment tool it's almost guaranteed that you'll be misaligned, and stabbing the tractor back together will bend the clutch disk.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
