Re: SA locked engine
Posted by redforlife on April 14, 2014 at 14:19:58 from (68.234.121.124):
In Reply to: SA locked engine posted by testanley on April 14, 2014 at 13:18:31:
brian & bill are right, and check that. Ussually rocking the wheels back and forth with transmission in high gear will get it back right again without removing the starter. First you might make sure the cylinders are not full of rain water or antifreeze. If it is seized from rust, it can't be seized much since not set long. If so, a squirt or two of oil in the spark plug wholes and let sit awhile and rock the wheels in gear will more than likely free it up. If you got anitfreeze in cylinders, you got problems, a crack or bad head gasket.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
