Posted by Janicholson on April 14, 2014 at 15:08:56 from (74.60.94.18):
In Reply to: international TD8C posted by slider1xc on April 14, 2014 at 14:27:19:
The right track clutch has likely become disconnected at the linkage, rusted/corroded/gummed up or frozen in the connected condition. The only way I know to free it is to make sure it is being actuated by the lever, if so then work that clutch against a hard push while pulling the lever. If the clutch is locked up the brake will have little effect. The linkage might cause both to stop working at the same time. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
