Re: Pushrod
Posted by redforlife on April 14, 2014 at 15:23:56 from (68.234.121.124):
In Reply to: Re: Pushrod posted by Farmall4856 on April 14, 2014 at 14:23:10:
I'll be nice (unlike the other post). The cylinder with froze valve would be a dead cylinder because of no compression. The tractor was likely running on only 3 cylinders with your valve like that. Also, your push rod would of popped out of the rocker arm because of the froze valve. Another point of advice would be to set all valve clearances while you are at it. Remember to have the cylinder your setting valve clearances on to be at top dead center of compression stroke (not top of exhaust) when setting the clearances. Set both exhaust and intake for that cylinder, then rotate another cylinder to top center of compression and set those, and so forth.
