Re: Farmall 300 clutch problem
Posted by rhtx55 on April 14, 2014 at 19:10:48 from (68.185.207.25):
In Reply to: Farmall 300 clutch problem posted by Danny D on April 12, 2014 at 12:16:10:
The clutch pedal has a square headed stop bolt with a lock nut just below where the linkage from the front attaches to the pedal itself. Assuming the free travel has been set at 1 in from the deck plate, and the T/A lever linkage has been adjusted to give the correct free travel, per the manual, it sounds as if the new clutch has " worked itself in", I would back the stop bolt off a turn at a time until the tranny doesn't grind when going into gear. The clutch has "worn in" since you have really been working the tractor, that's all. If adjusting the stop bolt doesn't fix the grinding into gear, then the advice given above would be a good place to start.
The only other issue I can think of is on my 55 F300, the T/A "stops" the tranny when pushing the clutch pedal all the way down when stopped, about 1/2 to 3/4 in from the bottom the clutch is released from the engine and the T/A is just beginning to catch on the way out ? Hopefullly... someone more experienced here can explain it better, but I could never get the free travel, clutch pedal, T/A lever adjustment synchronized until I purchased a manual, once I adjusted everything in sequence to the manual & to the specs given, no more shifting problems.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
