ih 340 engine
Posted by 1hunter on April 15, 2014 at 06:30:02 from (67.201.175.74):
My 340 lost power so I got it in the garage and started checking. Did compression check #1,2,4 was 135lbs #3 was 75lbs. Pulled the valve cover and #3 had a bent push rod. Straightened it and did another test. Same 75lbs. pulled the head and #3 badly scored probly broken ring. #1,3,4 have the same piston heads and #2 is different. Has anyone seen this before?
