Re: TA Adj From Manual
Posted by D Slater on April 15, 2014 at 13:00:20 from (184.14.205.2):
In Reply to: TA Adj From Manual posted by kelly in tx on April 15, 2014 at 10:52:24:
If I remember correct, disregard the stop bolt part of a 300 and use 1/8 inch instead of 3/16 for the t/a handle link rod pin with the t/a clutch shaft turned until release bearing just bumps the t/a clutch fingers. Other measurements the same.
Reason for not being the same is after 300 and 400 tractors the stop bolt and clutch pedal travel setting was dropped. No stop bolt on later pedals, also the top part of the T/A clutch operating shaft lever length was changed after 300 and 400 tractors.
This post was edited by D Slater at 15:40:16 04/15/14.
