Posted by Janicholson on April 15, 2014 at 14:43:09 from (74.60.94.18):
In Reply to: TA Adj From Manual posted by kelly in tx on April 15, 2014 at 10:52:24:
I decided to add to the information My solution to worn link pins and pivot points so the TA works correctly:
I adjust a worn set of linkages so that the pedal releases the shifter when pushed down 1/2 the distance to the full pedal travel from the place where the main clutch begins to move the tractor. As the vet said, set the master clutch freeplay, (1.25 inches from the platform measured at the point where the pedal arm touches the platform. Next, tape a wooden 12" ruler next to the clutch arm so it sticks out forward past the pedal about 6 inches. With clear space ahead of the tractor, put it in first direct, and let out the clutch slowly. as you begin to move note the location of the beginning of tractor movement on the ruler (the number doesn"t matter, it only allows you to know where the clutch starts to move the tractor.) Stop the tractor, and mark that spot on the ruler. with it shut off, and looking at the ruler, note how far it is from that mark, to fully pushed pedal. Set the TA clutch so it releases at 1/2 that distance. this setting allows the pedal push to release both clutches when pushed (correctly) to its travel stop. and assures that the TA clutch is fully engaged before the master clutch begins to move the power into the gears. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
