Re: Super M disc brakes vs W450
Posted by D Slater on April 15, 2014 at 15:30:24 from (184.14.205.2):
In Reply to: Re: Super M disc brakes vs W450 posted by Duner Wi on April 15, 2014 at 06:23:37:
third party image
On a late M and SM tractors with disc brakes the differential carrier and bull pinion housing on the right in the picture doesn't need removed to remove and install the bull pinion gear. M&W hand clutch uses a different bull pinion gear than shown. Bull pinion bearing retainer and brake plate on left is replaced with a plate to mount the band brake and clutch and brake cover on the M&W. Special bolts mount the plate to the differential carrier retaining bolts. Even though the differential carrier isn't removed from the transmission housing original IH size bolts need to go back when changed to original.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
