Did you go look at the pictures in the link that Hendrik provided above? It shows all the parts you need and how they are mounted to the tractor, very clearly.
Yes, the drawbar mounts to the holes at the FRONT of the final drives.
The second chain is a side stabilizer. Some plows do not have these, but apparently yours does.
Depth control is a lever that mounts to the right final drive via a bracket. A short "dogbone" linkage connects the lever to the turned-around drawbar. This allows you to move the drawbar up and down several inches, changing the angle that the plow goes into the ground.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
