Next plate on bottom behind the one under the clutch has a drain plug in the center. One in front and rear of transmission housing. When the oil gets to the proper level it goes in all compartments. When the oil levels out it will be up to or near both level check plugs. PTO oil is separate from the transmission unless a seal is leaking.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
