Re: 560 gas won't start
Posted by rustred on April 16, 2014 at 19:10:16 from (74.214.152.80):
In Reply to: Re: 560 gas won't start posted by Brad Vaughn on April 16, 2014 at 17:47:50:
first step is compression test, that will tell you if you have enough vacuum to draw the gas from the carburetor. it will also tell you if you have stuck or burnt valves. it will basically tell you the engines condition. you should have around 125 psi pretty much straight across with only 10 percent variation.
make sure you have the main needle valve open , about 4 turns from its seated position and the mixture screw 1 turn.
its also possible you can have a plugged orfice in the carb since it was sitting and you have not soaked it. pull the plug from carb bottom and make sure you have gas flow. it will run.
