Re: Re: Int. B275 Difflock
Posted by lee on December 22, 2000 at 13:39:06 from (198.133.22.93):
In Reply to: Re: Int. B275 Difflock posted by Andy Sinnamon on March 05, 2000 at 06:05:34:
You say it's like a locked box in your hands, but is it not still on the tractor?
All suggestions must be taken with a grain of salt with no guarantee suggested or implied.
I cannot recall exactly, but it seems there is a retaining ring in hiding on the shaft there. I think you have to pull the shaft out or depress the part the shaft passes thru (one or the other) against a rather stiff spring pressure to expose the retainer. I vaguely recall this as a challenging task to expose the clip and remove it against the spring pressure. You may want to enlist someone to help.
Assembly may be your next trick. I've not done that as yet. Looking ahead, I doubt you've removed your hydraulic housing. We can only hope you don't end up going there before it's all over. In all fairness, I don't think you should end up to your arm pits in hydraulic oil just to replace a shaft seal but I'd take a good look at a manual
to insure myself there's no chance that's where this leads. I can look at a manual and get back next Tuesday. Have a good Holiday.
Post A Followup
: Re: Re: Re: Int. B275 Difflock
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
