The old recomendation was 160 weight, more or less the same as the old 600W (not weight) called for in car rear ends up thru the 30"s. If you use 90 weight , plan on it marking its territory. Modern gear oil is not designed to work the same as the old sticky stuff was in the high pressures experienced between the teeth of straight cut gears. The modern oils will function fine for a long long time given the limited use of these old tractors but they will leak easier and you"ll notice alot more gear noise. The old grades of oil are still available but can be hard to find. Do not use hytrans oil.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
