Re: Cuts off under a load
Posted by ss55 on April 18, 2014 at 04:22:53 from (50.81.112.224):
In Reply to: Re: Cuts off under a load posted by Corey V. on April 17, 2014 at 17:17:41:
If a tractor does not run right, so that you can't fully test drive it to your satisfaction, discount it by 30 to 50 percent compared to one in running condition. The tractor could have more problems than just the engine. This one sounds like hasn't been maintained by someone that knows what they are doing. Look it over well and check the condition of the fluids.
Generally, if it is an easy fix the seller would have fixed it before selling it.
