Posted by WESnIL on April 18, 2014 at 04:31:35 from (206.221.154.153):
In Reply to: plows posted by kub6040 on April 17, 2014 at 22:13:12:
I have a Farmall 340 Diesel which will have 2 14s behind it. It will be for show and for plow days. No sense in pulling the guts out of these older tractors; I don't need to show off that bad. When growing up Dad had a 560 diesel, which ended up with a turbo on it, and 5 bottom plow behind it. That was too much in our hard plowing clay. But he wanted the biggest and you ended up using the TA lever a lot. Oh well, still good memories.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
