Re: pros and cons 504 diesel
Posted by Red Mercury on April 18, 2014 at 10:33:12 from (204.112.20.68):
In Reply to: pros and cons 504 diesel posted by dewy on April 18, 2014 at 10:13:31:
Sounds like a basket case. I have an International 504 gas which has been a good tractor but there are no wrecks around my area to find parts for it. This tractor has been in the family since new. It is not a real common tractor so CNH has limited parts for them as well. I wouldn't buy a 504 that needs quite a bit of work unless I had good access to a parts tractor or better yet, owned a parts tractor.
Pros: Good power steering, 3 point hitch, hydraulics, & IH 2001 loader. TA has been good but tractor is not used for pulling.
Cons: Poor brakes (since new), clutch "grabs" even when you try to let it out slowly (always has--not much fun trying to pin an implement to it), lots of little oil leaks because there are so many oil lines on it.
